Parametric round pot
Message 1 of 18
Hi Guys!
I need to make a parametris family. Its a round circle pot, and i want to move all togheter with just one parameter of radial.
Anyone know hoy to do this?
Sorry for bad english
https://postimg.cc/w1h091zB
Replies (17)
Message 2 of 18
Are you wanting to model a parametric pot like this?  Or are you just talking about a parametric 2D plan symbol?
Message 3 of 18
Something like this.
Message 4 of 18
Are you referring to those round planter walls.  You can use thick walls for those. They look to be about 18-inches high.
Message 5 of 18
Yes like that!
But i want to make a family to change de diameter as i need to be bigger or smaller
Message 6 of 18
It really quite simple. It's an Extrusion. Inspect the attached family to see how it is done.
Message 7 of 18
I need to undersytan how to set de inside radius parameters.
Message 8 of 18
Open the Revit family I posted and examine how I did it.
Message 9 of 18
and i need to know for example, i want to change de inside radius and i want the outside radius change togheter.
Message 10 of 18
i cant, rfa famili version 2019
Message 11 of 18
@Anonymous : You marked the wrong post as the Accepted Solution. Mark one of my posts as the Accepted Solution  and delete the one you gave to yourself.
Message 12 of 18
cant open de revit family u send me.
Message 13 of 18
Do you want me to send you a 2019 version?
Message 14 of 18
yes please.
i already unmarked the solution, i click de wong button 😂
Message 15 of 18
See attached 2019 RFA --  done especially for you.
Message 16 of 18
How can i do to change inside radius and mantain proportion on outside radius?
Message 17 of 18
I DID IT! THANK YOU MAN! U SAVED ME
Message 18 of 18
You can get there with a Formula the adjusts the Inside Diameter based on the width/thickness of the planter.
