Hi, I'm trying to make a parametric pergola. I'm almost there... I can change length, height and width. But, I'm trying to create a parameter to define the thickness and height of the pergulas/rafter, and is not working properly. I can define the pergulas dimensions (thickness and height) individually, but when i try to create a parameter to change all together (by array group) is not working (error: constraints not satisfied). I created the array and defined a label for the spacement between the pergulas/lines. But when i tried to change the dimensions of the cross section, gives me the error. I tried different ways, and i really cant do it. I'm new in revit... So if someone can help me... i would really appreciate it. I'm sending my file... so you can understand better what i'm trying to explain. Basicly, i want to define lenght, height and width of my pergola/gazebo... and i want to change the thickness and height of the lines/pergulas/beams... cause when the span is too big, i need thicker and higher beams.
