Parametric Pergola - Problem with Array - Please Help
Message 1 of 12
Hi, I'm trying to make a parametric pergola. I'm almost there... I can change length, height and width. But, I'm trying to create a parameter to define the thickness and height of the pergulas/rafter, and is not working properly. I can define the pergulas dimensions (thickness and height) individually, but when i try to create a parameter to change all together (by array group) is not working (error: constraints not satisfied). I created the array and defined a label for the spacement between the pergulas/lines. But when i tried to change the dimensions of the cross section, gives me the error. I tried different ways, and i really cant do it. I'm new in revit... So if someone can help me... i would really appreciate it. I'm sending my file... so you can understand better what i'm trying to explain. Basicly, i want to define lenght, height and width of my pergola/gazebo... and i want to change the thickness and height of the lines/pergulas/beams... cause when the span is too big, i need thicker and higher beams.
Replies (11)
Message 2 of 12
You must load a beam family with height and width parameters per instance within the family, make the array, insert the parameter in the dimension, then create the beam height and width parameters and associate them with the beam instance parameters.
 If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Message 3 of 12
Thanks, I tried... but when i choose a beam and load... does literally nothing. Can i load a family into another family? Cause my template is of a family. I'm trying to make a family of parametric pergolas.
Message 4 of 12
Yes, you can load another family. I make a video for you.
Message 5 of 12
Message 6 of 12
Muito Obrigado, de verdade!! Vc foi muito legal em fazer o vídeo... vou ter q assistir umas 10 vezes em camera lenta pra entender kkkk... mas com certeza foi o jeito mais efetivo. Se eu quiser abrir essa familia do pergolado parametrizado em um projeto novo e adicionar portas, janelas, coberturas eu consigo? Ou é melhor fazer o pergolado parametrizado sem ser em familia ?
Message 7 of 12
Já me inscrevi no seu canal kkk
Message 8 of 12
Obrigada...
Sim você pode carregá-la agora em todos os seus projetos, é muito melhor fazer famílias do que modelagem no local.
Assiste a fórmula mágica das famílias aninhadas, você vai conseguir entender melhor, não cosegui fazer com audio porque aqui ta muito barulho de criança kk
Em anexo a família que eu alterei.
Um abraço
Message 9 of 12
Muito Obrigado, Carime! Vc me ajudou muito. Vc é de onde ? Vc faz render ?
Message 10 of 12
última coisa, qual ano é o teu revit? o meu é 2019... não to conseguindo abrir o arquivo. _=)
Message 11 of 12
Eu sou Paulista mas moro em Orlando, no momento não faço Render... 😞 sorry
Poxa meu Revit é 2020... não tenho aqui 2019
Message 12 of 12
ah ta bom... vou baixar o 2020
muito obrigado
