Parametric Mullions
10 REPLIES 10
Message 1 of 11
ctough
1065 Views, 10 Replies
Parametric Mullions
ctough
I've got quite a clever sash window here but I can't work out how to get the 3x2 mullions to be parametric. They're fine when resized vertically but don't work horizontally. Please see the attached.
Parametric Mullions
10 REPLIES 10
Message 2 of 11
Alfredo_Medina
in reply to: ctough
Alfredo_Medina
Please provide more information. You meant to post an attachment but it's missing.
Message 3 of 11
ctough
in reply to: Alfredo_Medina
ctough
Hi Alfredo.
The attached is a standard window from the Revit library. It had glazing bars set at 2x2. I want to change them to 2X4 but I can't work out how to get them to work parametrically. Any ideas?
Hi Alfredo.
Message 4 of 11
Alfredo_Medina
in reply to: ctough
Alfredo_Medina
I see that the family has a parameter called "Glazing bar thickness". Have you tried that?
Message 5 of 11
in reply to: ctough
Is this what you are after?
My suggestion would be to open and load into your family the OOTB "Muntin Pattern_2x3.rfa" located in the stock Revit Content Library under Windows\Nested Families\Muntin.   At minimum, open it to see how to build one of your own.
2023 attached.
2023 attached.
Message 6 of 11
in reply to: ctough
@ctough wrote:
Hi Alfredo.
Regarding how to make them add or remove muntins parametrically, they need to be arrayed.  That's a little more involved. Download Marvin or Pella Windows to see how theirs are constructed.  Revit Families are available directly from their Websites.
....here's one from Marvin you can inspect:
@ctough wrote:
Hi Alfredo.
Message 7 of 11
in reply to: ctough
....or you could just steal and use their muntin family in your family. I won't tell. 😉
Message 8 of 11
ctough
ctough
 "Glazing bar thickness" - this seems to change the thickness, that's all.
I want the glazing bars to be evenly spaced when the window is changed in size. You'll see from the screenshot below that the default size (left) works and has 2X4 glazing bars that are evenly spaced but when I increase the size of the window, they get messed up. I don't know what I'm missing.
Message 9 of 11
ctough
in reply to: barthbradley
ctough
Yes, this is what I'm trying to achieve but 2X4 format.
Thanks, I've opened it. I know how to make extrusions but what I don't know how to do is make them parametric and evenly spaced.
Message 10 of 11
ctough
ctough
That window is the holy grail! Exactly what I'm after, to be able to edit the amount of glazing bars/muntins. I'm not sure how to go about using array though, it's not selectable when editing the extrusion.
I've inspected the Marvin one and it's blown my mind with the formulas and parameters etc. I wouldn't know where to begin.
Message 11 of 11
ctough
ctough
I wish I knew how! I've loaded it in as a family but the formulas haven't transferred over. I wish you would tell!! lol
