parameters of unknown origin overriding window placement
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey all,
I have a window family I created for a structural team that is basically just an opening that they can use to match opening sizes for their model to allow for header & hold-down placement. The head height parameter is set to type based since its fairly consistent in the project.
Once brought into their project, these basically go out the window and they are forced to set the windows via sill height per the parameters shown below.
While the sill height parameter is correct, the head height one is obviously not and unnecessary / confusing. Can someone help me remove this parameter / get it to report accurately? Moving it to the constraints portion of the parameters would also be a bonus. Its not associated with the family and they don't have a shared parameter file or global parameters to remove it from that I can find.
Hopefully someone on here has run into this before and found a way out.
Thanks in advance,
Dave
