parameter with no value doesn't export
p_campanaZ5Y6W
p_campanaZ5Y6W
Hi All,
i need to export a pset, some parameter need no value because is request that should be valueable in ifc editing software, why i can't see this parameter in a ifc viewer as bim vision?
Best regards
Paolo
mhiserZFHXS
I'm not sure why you wouldn't see it, whether it thinks exporting a null value isn't necessary or what. But what kind of parameters are they? If they're text, could you just put a space in there?
p_campanaZ5Y6W
Thanks for reply, parameters are related to a customize set, probably the fast way is to put a space ora some example text as you told, i hoped should be connected with ifc export options.
RDAOU
@p_campanaZ5Y6W
Im not sure if this makes your life easier, you just need to fill the values for 1 element in the model and it should be sufficient to export the pset for all other nulls empty in IFC
p_campanaZ5Y6W
Thanks a lot
