Parameter that reads Keynote table?
Hi.
I wonder if there is a way to create a Procject/Shared Parameter that can read the Keynote Table?
martijn_pater
A keynote schedule writes/assigns values to parameters based on a key. You just have to add this parameter to the Key schedule fields.
You can create new project/shared parameters under Manage --> Project parameters (settings tab) --> Add and then select project/shared parameter with name under the category you want to use it for ie. parameter for walls select wall category. Then in your Keynote schedule go to fields tab and add the parameter to the schedule.
My task is too create a Parameter to rooms. I´d like the parameter to work in the same way as the Keynote does.
Is this possible?
martijn_pater
Ow, you weren't talking about key schedules sorry I misunderstood. But in that case I can't answer your question I don't really know if that is possible...
