Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Parameter in Wall Niche Family
hliS658H
hliS658H
I have created a wall niche family, the height is a parameter, however it doesn't show after being loaded into project. I assume it might caused by the dimension of 4'-6", but it stays the same even after I delete this dimension. I have attached the family here.
Is it above the View Range Cut Plane?
jvpantin2
What do you mean with 'does not show'? Because is a type parameter it showns at Type properties windows (Properties palette / Edit type button). If you want to keep it visible directly in Properties palette, then you have to change it to instance parameter, it also means that 'height' value will be different for each niche you place in model.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
hliS658H
I meant why "height" doesn't show under "dimensions"
Change it from Type parameter to Instance parameter.
hliS658H
I see. Thank you for your explanation! Just fixed it.
