Parameter in Revit
Parameter in Revit
Parameter in Revit
Good morning, I 'm looking for a parameters list to insert into a bearing wall in concrete, such as compressive strengths, Flexural Strengths, Modulus of Elasticity, ductility, density, resistance to abrasion and corrosion etc...
cbcarch
Some of these properties are reported by the Material. Go to Manage>Materials>cast-in-place concrete.
Then look at the Physical Properties.
See attached screenshot.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
I saw your screenshots but I would insert other PARAMETRI more than the ones on your screenshot. Is it possible? How can I do?
*parameters
cbcarch
I do not think it is possible to add more parameters to the Material's Physical Properties, as it is contained in the adesk matlib file.
Perhaps you can ask this question on the Revit Structure Forum--someone there may know a bit more about it there.
Cliff B. Collins
ok thanks, i can ask this question on the Revit Structure Forum
