I need to calculate the diagonal of an escalator with parameters of a revit family.
With the following equation:
D = Diagonal (mm)
IF = Inferior Length (mm)
SL = Superior Length (mm)
h = Height (mm)
inclination = (degrees - o)
Diagonal = sqrt((Height^2)+((IF + SL+ (Height/tan(Inclination))^2)))
However, Revit returns that I have an inconsistent unit.
One part of the equation agrees:
(IF + SL+ (Height/tan(Inclination))^2)), but when it is included (Height^2) or sqrt. Revit the inconsistent unit warning message.
I tried to calculate in a separate parameter (Height^2), but the message persists.
Thanks if anyone has a tip.
Solved by ToanDN. Go to Solution.
Sounds like you need a neutralizer. That is, divide by 1 or multiply by 1.
