Paint Lines on Wall (As per image)
How would I drawing the paint markings on the wall shown in the sketchup image.
constantin.stroescu
  • in axonometric view as in your example : Home (Architecture )> Work Plane>Set >Work Plane - pick a Plane...pick on the face you want to draw - the face highlighted in blue, select it.
  • Model > Model Line..draw the lines you want to on this face ( a wall face, roof face..or any other...)
  • These lines are visible in 3d axonometric views and perspective view, elevations in all Visual Styles except the raytrace.... the same like in other softwares the lines can be seen only in non realistic view, not in rendered ones....
Constantin Stroescu
Is there anyway of filling or colouring the lines?
you could make small thin masses..
loboarch
Another option for something like this would be the Split face tool and then once the wall face is split you can then use the paint tool to paint another material on the wall in just this area.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
