Show only
Search instead for
Is there a way to edit a pad after it is inserted into a toposurface? I
need to change the size of the pad to match my new floor plan configuration.
John Fleming
John Fleming
You need to go to a view where you can select the edge of the pad, then the edit button will appear in the option bar and you can re edit the pad sketch.
