Overriding Graphics in a symbols Legend
5 REPLIES 5
tstewart
577 Views, 5 Replies
Graphics override is not showing all elements of door/window as demolished. How to show all elements as demolished?
5 REPLIES 5
in reply to: tstewart
Hard to tell.  Share those door and window families here.
tstewart
in reply to: ToanDN
Families are Windows & Doors.
BIM-CONG
I did some tests about this issue, I guess you are using legend view to make door/window shown as demolished by "Override Graphics in View-by Element", I redo this issue.
After some tests, I found the function "Override Graphics in View-by Element" can fully affect Elevation view direction, but partially Floor Plan view direction. The graphic override of the other parts seems to be controlled by other method. But there are on "Legend Components" in VG.
I found a alternative way to override the legend components, make all of the elements into a Selection, and use a Selection filter to override the graphic, and it will work.
Additionally, make sure to override both projection and cut lines, they control different parts of the elements. And I think its the reason why "Override Graphics in View-by Element" can only affect parts of it, for there is only projection lines override function in it.
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
- BIM THE FUTURE -
tstewart
in reply to: ToanDN
I have a working solution.
Thank you,
tstewart
in reply to: BIM-CONG
Thank you.
