Overlaying multiple Revit floors...
sstattelman4GLLM
sstattelman4GLLM
Okay, lets see if I can explain this without being super confusing. I have a circular project that ramps up to multiple levels. However, this is a school project and I don't want to show 5 different floorplans, so I'm trying to find a way to create a floorplan that looks like it is cutting through 4 feet on each level, instead of the lighter underlay that isn't as graphically pleasing. I was just wondering if this is possible, or if I should photoshop the different levels onto one another. Again this isn't for a construction document, just a visual aid. If you need anymore info or the file just let me know.
Thanks!
Sean
You can create floor plans of the levels that you want to see with different cut planes and then overlay the views on a sheet.  You can crop each view to see the part that you want to see, and change each graphically to suit.
sstattelman4GLLM
Thanks Tim! Didn't think of that at all, should work though!
