Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Overall Project Accuracy
1 REPLY 1
DancinoMan2615
285 Views, 1 Reply
Revit as a standard is set to the accuracy of 1/256". I know how to edit the dimensions when it comes to rounding. Is there a way to only allow the actual drawing in model space to be a different accuracy?
For example, if I wanted my lines in model space to be drawn in 1/16" increments instead of 1/256", is that possible?
Thank you,
1 REPLY 1
in reply to: DancinoMan2615
Set it in Snaps settings.
