Outlets not showing in callout
Message 1 of 13
Anybody run into this problem [Revit 2014, Build 20140709_2115(x64) Update Release 3]:
1/4" floor plan shows data, phone, and electrical outlets just fine. If I do a callout, I can see everything well, just not the outlet symbology. If I create an outlet in the blow-up plan, I don't get any errors, but it only shows it in parent view. I can see the boxes in the callout, just not the symbols. Any ideas what could be causing this and how to resolve?
Thanks.
Replies (12)
Message 2 of 13
CoreyDaun
Check the Callout's Detail Level; in the OOTB outlet Family, the symbol becomes hidden and the geometry becomes visible under Detail Level: Fine.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 13
Thanks. I've checked the family, and the symbol is set to show under Coarse and Medium (off in Fine). In the callout I had already tried all Detal Levels, tried matching the scale of the parent view, tried wireframe.... Still nothing.
Message 4 of 13
CoreyDaun
If you are seeing the outlets' geometry (or Symbolic Lines, as per the OOTB Family), open the Family and see what Detail Level they display in. I opened the Ref. Level Plan and the Symbolic Lines are set to only show on Detail Level: Fine. If this is the case for you, then the Detail Level is likely the issue; I suspect that somehow, the specific Category(ies) is/are being set the Detail Level: Fine under Visibility/Graphics Overrides.
Message 5 of 13
This view does not have any View Template overrides, the Detail Level settings in VG are set to By View for all with no further modifications. What I'm seeing is the 3d wall box, but not the 2d symbology.
The only other thing that seems unusual to me is that if I do try to set a View Template, my only options are "... Elevation" and "... Section" even though this is plan. Could it be that Revit is interpreting this plan callout as a section? I have deleted and recreated it multiple times all with the same result.
Message 6 of 13
Let me rephrase: my DEFAULT options are for elevations and sections.
Message 7 of 13
chrisplyler
Right.
You've got the power to MAKE a new view template. Go to the view that has the outlet symbols shown the way you want them, go to the View menu and make a template. Now go to your callout view where they aren't showing and apply that template to it.
Be warned that every setting will be transferred, unless you first modify that template not to include the stuff you don't want to change, such as scale for example.
Message 8 of 13
Great idea - I remember fixing some other problems this way. Unfortunately this didn't work either. I created a view template from the current parent view, and applied it directly to the callout (all setting - nothing turned off), but still no go.
This might just be an issue for Autodesk tech support....
Message 9 of 13
chrisplyler
Then I'm stumped.
Message 10 of 13
SteveKStafford
My bet is that your callout is a Detail Callout, not a Floor Plan Callout?
I don't know why but then nested annotations in outlets don't show up in Detail Callout. You also can't create a room/space in the view either. It is intended as the last stop or end of the road with regard to drafting up a detail, we are NOT going to greater detail than THIS.
Steve Stafford
Message 11 of 13
chrisplyler
What is a "Detail Callout" view? How is this created?
Message 12 of 13
SteveKStafford
View ribbon > Callout. There are usually two type in the stock templates; Floor plan and Detail. The same is true of sections and Callout that are created in section views.
Steve Stafford
Message 13 of 13
Be sure to have checked "Generic annotations" in Visibility/Graphic - Annotation categories.
