Orthographic assembly glitch.
I'm in Revit 2017 A360 and am having trouble with a 3D Orthographic assemblly.  After placing it on a sheet everything seems to be fine, but hours later the view will rotate on its own.  It seems to rotate to the same angle each time.  I have tried pinning it but that doesn't seem to help.  Does anyone know how to solve this problem.
Thank you.
DanFaba
Hello, Jake
I have reviewed the information from your post, and it seems very much alike the other post we have at
http://forums.autodesk.com/t5/revit-structure-forum/orientation-of-assemblies/td-p/5838139
I would recommend you to review it, to confirm if this information is useful for your current problem.
Dan Faba
Autodesk Revit Technical Support
To further clarify I have attached two files.  The '3d ortho' file is how I want it to look.  I am able to rotate the view but it won't stay in the orientation that I want.  The '3d ortho 2' is a screenshot of what it looks like when i open the file each morning.  I am not having problem with any of the 2d assemblies.  Only this one ortho is giving me problems.
Jake
