Origo to a pattern? Adjusting a pattern?
Hey!
I have a little pattern problem....
I want to put a pattern to the bathroom so that the vertical lines are aligned to the door or wall. That is a real situation, when you put plates to the wall, you start from the adjoining wall or from the door line.
The problem is that, how can I adjust the pattern? Where can I set the origo to a pattern? Must I go to the text editor? Hopefully not! 😉
Thank you!
***************** Greetings from Finland! **********************
By Matti Kettunen 🙂
Alfredo_Medina
Align > select the edge of the door frame > select one of the vertical lines of the hatch pattern.
Yes! 😄
Thank you Alfredo Medina for your reply and advice!
And many thanks for your previous advices too! 🙂
This forum is really very good and useful method to get specified information!
It saves a great deal of time!
Best wishes,
Matti Kettunen 🙂
