I am wondering if there is a way to create tick-arrow dimensions on an arc? To my understanding Revit does not have the function to do a tick and arrow within the same dim style so I have been using ordinate dimensions as a work around but it doesn't seem to work for arc dimensions. Has anyone ran into this problem and/or found a solution?
Thanks!
Thanks!
You could try using the Massing & Site tools to place a "mass" that is the Arch and then use the Divide Path command to divide the arc. Those divisions won't show up, but you could place a detail component I guess.
