opening a recovered file
I recovered a Revit file which was accidentally deleted by me,so i restored it using Recuva but  it says failed to open document. Please help me recover the file. It is really important.
I can't open it either. Do you have backups of the original file (appended with a 000 extension)?
cbcarch
You will probably need to open a case with Autodesk, they can recover most corrupted files.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Corsten.Au
Check for user file location, Seems that file was central and local files are created usually in Documents folder.. you might be able to use local file and save it as new central...
give it a go..
Cheers!
Corsten
Building Designer
