open stringer at stairs
tpreisler
Message 1 of 10
tpreisler
Hi, Please see photo attached. How can i have this stringer close all the way?
Replies (9)
Message 2 of 10
JacobDSimpson
When you have your stairs, go to edit - check both your stringers are set to closed as so in the image. Stringer on.png
Message 3 of 10
tpreisler
Sorry, i didn't explain. I need stringer below stairs should be closed without a gap at mid landing. I don't want stringer above my tread.
Message 4 of 10
JacobDSimpson
You should be able to adjust the tread depth, you can still see the option in the last image
Message 5 of 10
tpreisler
I see the problem, both landings don't give me a carriage so the carriage of the stairs don't continue,. Is there anyway to have it by landing as well?
Message 6 of 10
JacobDSimpson
I'm not 100% sure, if you go to the stairs, hit edit and select the landing. If you then go on to the landing you can edit that and tick 'same as run' or not
Message 7 of 10
tpreisler
Sorry, it wouldn't work.
Message 8 of 10
JacobDSimpson
Sorry, I'm not sure. Have always found stairs a nightmare in revit!
Message 9 of 10
PijPiwo
Use tab key to select a carriage (any carriage). Click Edit Type in Properties and make sure Structural Depth On Landing is not 0.
Message 10 of 10
Did you actually add Support to the missing segments at the landing?  And check Structural Depth on Landing as suggested.
