Open cut out
Open cut out
mphungDCHNW
Message 1 of 13
Open cut out
mphungDCHNW
I am trying to have another open cut out in my sweep sketch path however its not allowing me. I have tried creating a void extrusions but its not cutting through the sweep.
I was able to create one opening from the sweep.
Replies (12)
Message 2 of 13
You can't cut through it with any method. There are workarounds though.  Maybe a different rail at that location would be easiest.  Pretty much how it will be constructed in the real world.
...or are you just trying to create an opening.   If so,  don't put a Rail there.
Message 3 of 13
mphungDCHNW
So should I make singles pieces? The rail itself I modeled in placed it
Message 4 of 13
In-Place?  So it's not done via the Railing tool?  If it's Modeled in place, then edit the In-Place Model and cut it with a Void there.
Maybe I'm not reading you right.  Did you Model it using the Rail Tool. If so, Clipboard Copy/Paste Aligned to Same Place. Now you have two identical Railings overlapping. Edit each one and change the Sketch path so they don't overlap. Get it?
Message 5 of 13
....see edited post above.
Message 6 of 13
The void and the sweep should be in the same in place model.
Why don't you use railing?
Message 7 of 13
mphungDCHNW
I modelled in place the railing and creating a plane or another generic object to be aligned with the plane and then created the void extrusion based off that plane but it still doesn't cut through the generic railing.
I think I might just create a custom railing sweep with the custom cut outs to match what I need unless there is a easier way.
Message 8 of 13
Void and sweep must be in the same in-place.
Of course there is, it is called Railing.
Message 9 of 13
Maybe you mean something different by "In-Place" than I do. In-Place means the Railing was created via the Model In-Place tool under Component on the Architectural tab. Is that what you mean?
Message 10 of 13
An alternative to the Railing tool would be Curtain Walls.  Mullions for the rails and Empty System Panels for the space in-between.
Message 11 of 13
mphungDCHNW
With railing you also can't create multi cut out because it is in a closed loop hover you can cut/split the railing elements.
Message 12 of 13
mhiserZFHXS
It sounds like you are really overthinking how to create railings... As pretty much everyone else is saying, use the railing tool. There is no "cut out" in real life. They are two separate railings. So model two separate railings.
Message 13 of 13
Yes you can use Split tool to split a railing to create a gap, or simply draw separate railings with a gap between them.
