Only some Hidden Lines displaying when exporting to PDF
LF-MS
Observer Observer
LF-MS
Observer
Observer
Hello!
I have been working on fixing some Cabinet Families, working in Revit 2024, and noticed while exporting to pdf that only some of my hidden lines are appearing for the base cabinetry. I have Revealed Hidden Lines for all the families and checked that all the graphic visibility settings are the same. In Revit I can see all the hidden lines, however as soon as I export the sheet to pdf, some vanish.
In the family, the lines that are vanishing and showing up are: Symbolic Lines with an Identity Data Subcategory set to Plan Rep - Below [projection].
I am exporting using vector processing. When testing it out using raster processing, all hidden lines appeared, but the quality (even when set to presentation) seemed to have a slight blur/fuzziness to the drawing.
 (pdf view with some of the hidden lines missing)
 (revit view prior to exporting to pdf)
 (export settings)
Please let me know if anyone has some insight as to why this might be occurring!
Thank you so much in advance:)
vitorbortoncello
use raster processing
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
