Offsets from Location/Reference Lines
- Mute
- Permalink
- Report
The Problem
As architects we often have our slab edges offset from the perimeter (for curtain wall or brick, for example), but we want the slab edge to follow the same line as the wall. Through the DD process the exact floor location may shift around, which means you have to endlessly re-trace the floor profile.
Similarly, when doing quick design studies you often want to push things in and out - the only option in Revit is to move the actual wall or profile.
The Solution
Offsets!
Imagine this - if you set your perimeter of your floor to hug the exterior face of your wall, but you type in an offset for the floor itself. So instead of the floor hugging the wall face, it can be set in a certain amount, everywhere. This would let us inset floors behind walls when using "model by face" with masses, and it would also let us make quick design changes. Similarly, if you place a wall and want to change it (say to move it "out" to see how it looks in the design), instead of moving it around you can just change the offset to a different number, look at it, and change it back if you need to.
Your competitor, ArchiCAD, has had this function for walls for at least 15 years and it is excellent as a design tool. Floors may be trickier but I believe in you Autodesk!
