Odd 3d behavior
Odd 3d behavior
Message 1 of 12
Odd 3d behavior
I have recently started a new project of construction drawings for a new build apartment scheme. Everything was working fine until i got up to the roof level and started modelling a dormer. Now the 3d view no longer highlights objects that i am hovering over and weird lines have appeared everywhere. The floor plans and elevations are still fine though. I have tried recreating the 3d view, and opening it on a different PC to no avail.
Below is a screenshot with my poorly drawn red circles showing the errors.
Any ideas anyone?
Replies (11)
Message 2 of 12
Use your Join Geometry Tool.
...You mean you can't select them? Check to see if you have selection restrictions.
Message 3 of 12
Did you link any DWG files in recently?
Message 4 of 12
There are a few DWGs that have been linked into the floor plans since i started the project. Could this be the cause? Everything was fine until i started working on the dormers / roof.
Message 5 of 12
Everything is already joined. I can select things, but nothing is highlighted when i hover over until i actually click it which isnt normal behaviour .
Message 6 of 12
Ah dormers.  Edit the sketch of the dormers and make sure all the corners are trimmed cleanly.
Message 7 of 12
Wrong Thread. Sorry.
Message 8 of 12
Wrong thread. Sorry.
Message 9 of 12
@barthbradley wrote:
@ToanDN: did you mess with it? I think Revit is spazzing out over all the Wall Profile Editing with Attaching going on in the Project, as well as the placement of Windows those Profile Edited Walls.
I didn't see any file attached.  Did he send it to you directly?
Message 11 of 12
I removed the dormers completeley and it hasnt fixed itself.
Here is the file if anyone wants to take a look.
https://www.dropbox.com/s/zohxqurz7vtjdlg/error%20file%20-%20purged.rvt?dl=0
Message 12 of 12
Only way i found to fix it was to create a new project, copy everything from the broken model (levels and all) into the new project and recreate all of my views. Not ideal and a bit of a setback, but at least everything is working fine now.
