Octagon roof
2 REPLIES 2
3100 Views, 2 Replies
Octagon roof
Sort of newbie to revit, Im trying to get a 8 sided gazebo roof with a 6/12 pitch, I've tried each one seperate but then I get the "lines must not overlap" or "lines must form a loop" error, spent too much time trying to connect, reconnect lines, etc...any suggestions are greatly appreciated, thank you .
Dallas
Octagon roof
Dallas
2 REPLIES 2
SteveKStafford
SteveKStafford
It should be pretty easy. Start Roof by Footprint. Select sketching option Polygon (either circumscribed or inscribed), sketch the desired size roof. Alternatively you can use pick walls, set a desired Overhang on the Options Bar (just make sure your walls are forming a good octagon first). Double check the pitch of each roof sketch segment and then Finish Roof.
Steve Stafford
Steve Stafford
in reply to: SteveKStafford
Thanks Steve, duh.....I should've knowed.
Dallas
Dallas
