Obscured lines style in 3D view
Message 1 of 10
Hello, is possible to change style of lines hidden by model itself without changing it manually by Linwork method?
Replies (9)
Message 2 of 10
GustavoUbriaco
Maybe you can change them using show hidden lines
Gustavo Ubriaco Contreras
Message 3 of 10
As far as I know this method uses two elements as input.
Message 4 of 10
Jamhmer_Oc
Hi @Anonymous
Jamhmer Oc
Message 5 of 10
Message 6 of 10
GustavoUbriaco
This is the best way
Message 7 of 10
Yes. Change the view's display hidden lines to All and change <Hidden> sub object style of the applicable categories to what you want the obscured lines to show.
Message 8 of 10
It's a good suggestion. Whether or not it is "best way" would depend. It may not work if the construct the OP is showing in his/her screenshot is a single family or several families.
@Anonymous : what are you showing?   Looks like Walls and Footings to me.  Is that right?
Message 9 of 10
GustavoUbriaco
Yes and not, if you use in the properties pallete show all hidden lines this is the result and it's automatic, if you use show hidden lines in the ribbon you'll ned 2 objects and is'nt automatic
left side was manually and second one is automaticleft side was manually and second one is automatic
Message 10 of 10
Thanks all of you for help, @ToanDN and @GustavoUbriaco  suggestions about changing the views display hidden lines to all solved the problem. As @barthbradley  mentioned I could be more specific about subject of question, it was single family created in dynamo.
