objects turned to red color
Shamseera.kk73D7Q
Message 1 of 8
Shamseera.kk73D7Q
I was working on Revit roof plan of a building. accidentally some key got pressed and whole objects turned red color. color change is only in this view. other views are fine. how to return it to default black color?
Replies (7)
Message 2 of 8
apjones
If it is a work shared project, you may have accidentally turned on the workshare display and everything is on one work set which has defaulted to red.
Check the button shown below.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 8
Shamseera.kk73D7Q
its off
Message 4 of 8
RDAOU
@Shamseera.kk73D7Q
that’s due to phase and phase filter applied to the view. Red usually is the color of new components created in the set phase.
on the properties panel change filter to none or to complete
Message 5 of 8
Shamseera.kk73D7Q
I tried that also. but its not working. Now what I did is I selected each element and override graphics and change it to black in projection lines color.
But its not the right way.
Message 6 of 8
RDAOU
From the information you have provided one cannot tell the exact reason; hence, you would need to go through all the graphics related options ...you already ruled out phasing
  • check if category overriden.
  • check if there is a filter applied to the view
  • are they in a link (Revit/CAD)? what are the link settings, by host or by link?
Message 7 of 8
Shamseera.kk73D7Q
Hi...
Category is not overriden. There are no filters applied to that view. Its not a linked Revit/CAD file.
Message 8 of 8
RDAOU
Did you actually apply the Phase Filter None...when you do it should turn gray...Can you post an image of the Phase Filter filters and Phase overrides tab
Otherwise,
  • create a view template from a working view and apply it to this one
  • if the above doesnt work delete the view and recreate it
