Objects disappear
Objects disappear
DParkRMAK
Message 1 of 11
Objects disappear
DParkRMAK
I have been putting together a sample set of drawings for CAD standards and tuning my view templates and I noticed things were missing from my views. My sections simply will not show up in this view, then some walls were missing. I checked my template and everything should be showing. I never did anything with phases or options. I checked my view range and the extents of the section, No filters should be affecting it. I turned off the template and turned everything on but it still will not show! It was showing properly until today. I copied another template and changed the scale and it works fine. What the heck happened to break my view template? Is this a known issue? This happens fairly frequently and I need to figure out what causes this.
Replies (10)
Message 2 of 11
Check the value of [Hide at scales coarser than] of the disappeared sections.
Message 3 of 11
DParkRMAK
I did check that as well.  I changed the scale to the max and minimum trying to get my sections and callouts to show, but nothing worked. The only thing I did today was I adjusted the view range, but I have changed it back. I checked settings with a template that works, but nothing will turn these things back on. They are not hidden or turned off, This is crazy frustrating.
Message 4 of 11
Share the file here.
Message 5 of 11
DParkRMAK
Here is my Revit model purged. I would appreciate your input on this. I can't see any reason for this, but it is probably something simple and stupid that I am missing.
Message 6 of 11
Change the view Discipline from Structural to Architectural or Coordination.
Message 7 of 11
DParkRMAK
AWW FFS! Thank you. I knew it had to be something stupid simple. I did change that today to get my footings to show.
Message 8 of 11
mtennant
I'm having the same problem and i changed the discipline back and forth, but that didn't work the Detail level is on Fine... I still have missing elements mostly masses, windows, and doors...
Message 9 of 11
Message 10 of 11
mtennant
I tried that but it didn't work.  I'm running parallels, could that have anything to do with it?
Message 11 of 11
mtennant
 When i open the sheet all the elements are there, but when i zoom in or out elements disappear in view.  If you run your mouse over them they are still there.  If i delete them and then undo it, they reappear but then when i zoom in and out they disappear again.  Also when i print the sheet elements don't show up.
