Elevation of feature - disappear from floor plan?
cjacobsLDX59
Message 1 of 11
cjacobsLDX59
Hi all,
So I have a floor plan with a grid system and a bunch of structural elements (pile caps), each of which has an elevation (relative to the floor) associated with it.
The odd thing I've noticed is that more than once when I edit the elevation value, the pile cap disappears from the floor plan completely. Could this potentially mean that the elevation I'm putting in is too low for the level that floor plan represents? (...even though in this case it's the basement, so...lol)
Could anyone share some relevant wisdom with me :)?
Thanks in advance,
Replies (10)
Message 2 of 11
RDAOU
@cjacobsLDX59
They fell outside the view range of the view.
On the properties palatte edit the view range and adjust (depth and bottom)
There is a preview button on the  View Range dialogue which you can expand and inspect the schema which explains qhat each input value is for.
Message 3 of 11
@cjacobsLDX59 wrote:
Hi all,
Thanks in advance,
If you changed the elevation of the element to be outside of the view range they they will not show (except as Underlay, but it is beside the point).  So yes, you will need to re-adjust the view range to make the elements visible again.
Message 4 of 11
cjacobsLDX59
This is extremely helpful, thank you!
But when I did this, the symbol for the object changed color to red; might this be bad?
Message 5 of 11
RDAOU
@cjacobsLDX59
Red? No... that can't be bad. It wont explode so to say 🙂 probably just a category override, a view filter of the phase filters for element created in the current phase ie: new
Message 6 of 11
cjacobsLDX59
The reason I'm concerned is because other iterations of that same object are all green. And I guess the green/red transition is just somewhat alarming, haha.
Message 7 of 11
RDAOU
@cjacobsLDX59
As stated, nothing to be alarmed about... it could be phasing, it could be graphics overrides in visibility graphics, could be filters, or simply the assigned cut/projection lines in object Styles
Message 8 of 11
cjacobsLDX59
Okay. Thanks again! That really calms my nerves, haha.
Message 9 of 11
RDAOU
@cjacobsLDX59
Interesting choices you make on all your posts  ... becoming more of an obvious pattern 🙂
Message 10 of 11
cjacobsLDX59
If the pattern is that I'm new to this, then you guessed it! 😛
Message 11 of 11
RDAOU
Nope that was not it ... you are not really new to this 😉  on the contrary  you are more of an Expert
