Number Doors All The Same
PhilvK
Advisor Advisor
Message 1 of 12
PhilvK
Is there a way to select multiple doors and tag them all the same, such as EXIST?
Replies (11)
Message 2 of 12
Select the doors > Temporary Isolate > Isolate Elements in View > Tag All > Temporary Isolate > Reset
Message 3 of 12
RDAOU
@PhilvK
  1. Set Phase Filter to Show Existing (Alternatively set Phase to Existing and Show New)
  2. Select a Door >> Isolate Category (Temporary Isolate)
  3. Type Exist in Mark or Comment or any parameter you wish to Tag
Message 4 of 12
PhilvK
I might be missing something (or being dense), but I've done the same thing by filtering so only doors are selected. I tagged all successfully but they are numbered sequentially. I thought there was a way to give them all the same number.
Message 5 of 12
I thought you wanted to tag a them.  If you want just to change them to the same number then follow @RDAOU post.
Message 6 of 12
PhilvK
RDAOU - That works for one, but not all at the same time
Message 7 of 12
RDAOU
@PhilvK
Should Work for all as long as the parameter is the same in all See GIF below
Message 8 of 12
RDAOU
@PhilvK it Worked or still struggling with it?
Message 9 of 12
PhilvK
Struggling. I'll try again and let you know. Thanks for the reminder.
Message 10 of 12
RDAOU
@PhilvK
If what in the above GIF doesn"t help
  1. Create a Schedule for that Category (example Doors)
  2. Filter based on Phase Created
  3. Uncheck Itemize every instance
  4. Enter the Mark or Comment Value in the Schedule
Message 11 of 12
syman2000
oop....check the answer above. Create door schedule. Then set to a parameter you want to change. Then in the grouping, check OFF the itemized all. Then you go in and change the value. This will update to all the doors simultaneously.
Message 12 of 12
alan.johnson7YLND
you could use Type mark
