All the cut edges of the walls (doors, windows, etc.) from Revit model started shining in Enscape
3 ANTWORTEN 3
Nachricht 1 von 4
204 Aufrufe, 3 Antworten
I got a really odd problem. All the cut edges of the walls (doors, windows, etc.) from Revit model started shining in Enscape. Also the white objects like sinks got luminescence. I think it happened when I added some lamps with luminescence settings to my model. Other object materials don't have any luminescence in the settings and the walls material is wood. Does anyone know what it has to do with?
Thank YouEkrano nuotrauka 2021-12-06 193135.jpgEkrano nuotrauka 2021-12-06 192935.jpg
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: Anonymous
Can you check the Default Wall material? Normally those edges use this as default. If user accidentally change these default material, it will override all the wall edges.
Nachricht 3 von 4
Maybe a Material with a Self-Illumination Asset Property?
Nachricht 4 von 4
als Antwort auf: syman2000
Thank you, it helped! Somehow the light material was related to default wall and when I was editing the light, default wall material also changed. Now I created new light material and everything seems good. :leicht_lächelndes_Gesicht:
