Nudge/Arrow Keys Aligned to North in Default 3D View
andrewRHXPH
andrewRHXPH
Recently I noticed that when nudging objects in the default 3D view, the arrow keys became aligned to the project north direction. Usually the arrow keys would nudge an object, up/down/left/right based on how the view was oriented; for example, up moves the object up regardless of where "north" is. Suddenly, in the 3D view, the up arrow only moved and object north, the down arrow south, and so forth.
I managed to fix it by deleting and recreating the default 3D view, but does anyone know what setting this is, and how I may have turned it on?
tkbim
Try clicking on an orientation on the View Cube.
Then the nudging should follow the view orientation.
handjonathan
Hi @andrewRHXPH
Thanks a lot for posting your question to the forums!   Has the solution suggested by @tkbim helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
