Not Responding Message every other click
Message 1 of 12
I keep getting a 'not responding message' every other click and takes forever to clear up. This was not doing this two weeks ago. My file size is 15.5MB. I already did a clean install.
Specs:
Radeon Pro 460
16gb Ram
Replies (11)
Message 2 of 12
Audit the file.  Resolve Warnings.
Message 3 of 12
Followed the instructions here: https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2017/...
To no avail. The circle loading still shows when zooming in moving around changing views, etc.
Message 4 of 12
Do you have a lot of Warnings in the Project?
Message 5 of 12
Not that I can tell. No messages from the audit, and no warnings in the ribbon. It's a massing model. Project was working fine a couple weeks ago, not sure what changed.
Message 6 of 12
You have no warnings?! Good for you.
Hard to know for sure without examining file.  Post it here. We'll take a look at it.
Message 7 of 12
Going to post my site model as well as the linked revit file that needs to into it.
Site Model:  "New york site"
Linked Revit Model/Massing: "massing"
Message 8 of 12
Let me know if you were able to download the file.
Message 9 of 12
Nothing got posted.  You may need to ZIP the file before attaching.
Message 10 of 12
I have added the file to "attachments" if it isn't working, what would be another way to upload it? I found it would not let me attach two files here is a google drive
https://drive.google.com/drive/folders/18aQpVKKvvGjkwYhd13x4_4cSD6BnWSge?usp=sharing
Message 11 of 12
I got them both and open the Massing.rvt, and it nearly crashed on me twice. I can't risk crashing right now.  I'll check it out later if someone else doesn't come through in the mean time.  You may also want to open a support case through your Autodesk Account in the mean time.  They usually respond in a couple of days.
Message 12 of 12
bin
