If you added your own Shared Parameters to Labels in your Title Block family, you will also need to add those Shared Parameters to your project file. (If this is a standard title block that you expect to use on most projects, you will also want to add these to your template file(s), so that new projects have them from the get go.)
In your project file (and template file), on the Manage ribbon tab, select the Project Parameters tool.
In the Project Parameters dialog, select the Add button.
In the Parameter Properties dialog, select the Shared parameter radio button, and then select the Select button.
If the Shared Parameters file that has the desired parameter is current, you can select the correct Parameter group and then the correct Parameter and select OK. If the current Shared Parameters file is not the one with the desired parameter, select the Edit button. In the Edit Shared Parameters file, use the Browse button to navigate to the Shared Parameters file with your desired parameter, select the file and select the Open button. Then select the OK button in the Edit Shared Parameters dialog to return to the Shared Parameters dialog, with the correct Shared Parameters file current. You can now select the correct Parameter group and then the correct Parameter and select OK.
Back in the Parameter Properties dialog, in the Parameter Data area, decide whether the parameter should be type or instance based, and the browser category under which it should be grouped. Then, in the Categories area, decide what category(ies) to which the Shared Parameter should apply. If the parameter will be the same for all title blocks, the Project Information category is appropriate. If the value varies with each sheet, then the Sheets category is appropriate.
Select OK to dismiss the Parameter Properties dialog.
Select OK to dismiss the Project Properties dialog and add the Shared Parameter.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
