Non-Parallel Section
Message 1 of 22
I want to create sections parallel to beams that are at random angles (in plan).
How do you get the section to align parallel to it?
See attached screen shot with several beams at various angles.
Replies (21)
Message 2 of 22
Rotate the Marker.
Message 3 of 22
Yes, but how do you get it to be exactly parallel to the beam?
Message 4 of 22
RobDraw
Sections won't allow you to align or even snap to it, so you have to find out the angle and rotate the section by typing in the desired rotation angle.
Rob
Message 5 of 22
Use Ref. Planes that are 90 degrees to each other to assist you.
Message 6 of 22
Just one more thing to add to the long list of simple things Revit won't do!
Message 7 of 22
J.Wehmer
Obtain the angle of the angled element;
  1. Draw a Detail line touching the element at either 0°,90°,180°,270° point from the element. This will give you a baseline for your angle dimension
  2. Use your dimension (DI) command, and switch to angular dimension. Click the angled element and then the detail line drawn in step #1. This will give you to rotation angle needed for your section/elevation.
  3. Click your elevation/section and use the rotate (RO) command. Enter in the value obtained above and your section/elevation will be perfectly parallel to the point at which you dimensioned.
-Please click accept as solution if this answers your question!
Message 8 of 22
Depends on what you are aligning to. My markers automatically align in most instances just fine.
Message 9 of 22
That's a lot of f*****g around when it should be able to snap to the object you want it parallel to.
Revit making things difficult since 19??!
Message 10 of 22
I think your "U", "C", "K", "I" and "N" keys are broken, dude. Probably cookie crumbs in the keyboard.  he, he.
Message 11 of 22
RobDraw
Alternatively, you could draw a new section and Revit will highlight the gridline when you are parallel.
Rob
Message 12 of 22
use dynamo!
Message 13 of 22
loboarch
Yeah, sections will not snap to beams, walls, yep, beam nope.  Smiley Sad
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 14 of 22
Oh, did I say "most instances" instead of "wall instances"? My bad. Must be the cookie crumbs in my keyboard.  Smiley Wink
Message 15 of 22
use the pick line tool for a reference plane....use a framing elevation which will align automatically or the section will snap to the reference plane.
Message 16 of 22
Sweet.
Message 17 of 22
Draw a reference plane parallel to the beam and you can draw a section snapping to the ref plane. Repeat for other beams.
Message 18 of 22
Same thing I suggested 7 hours earlier 😛
Message 19 of 22
sorry i replied directy via my phone and didnt read all the post of the
thread.
Message 20 of 22
Match Rotation plugin is your friend . I use it to match section boxes as well - super useful.
