no visible section line in the plan view
Hello, I have created a map and copied this. Then I created a drawing and created the map in 1: 500 in a window. I make a cut in the layout plan and the cut is made only the cut is not displayed in my plan in the drawing. But it is visible in the original map.
How can this be done? I checked the visibility settings.
When creating the cuts in the plan, I receive the following error message:
"None of the elements created are in plan: Site Map Visible, you should review the active view, its paramenter and visibility settings, as well as the plan areas and their settings."
The discontinued discipline is architecture, but I've already tried all the others.
Best regards,
Alexander
VG > Annotations tab > Sections = ON
yurikim
Thank you for your posting @Anonymous.
This is the error message that you received, please check the solutions if any of them works:
Revit: None of the created elements are visible in the view
It sounds like copied element is attached out of the view range that you are currently in.
Cheers,
Yuri Kim
Product Support Specialist, AEC
ennujozlagam
hello, pick your section line symbol in your layout plan and check assign phasing and see if helps. thanks
I had this problem. This solved it for me. The section was hidden by scale.
Thank you!
llanto_leslie_mpc
Community Visitor
Community Visitor
thank you. great help.
