No "Workspace layout" sample study file in Generative study
lehaxathuc11
lehaxathuc11
I am using Revit 2026. I wanted to try out "Workspace layout" generative design but i couldn't find the sample file anywhere, and according to videos and tutorials online, "Workspace layout" seems to be among the default sample files by Autodesk.
I couldn't find it in the intitial "Create study" tab, or locate any "Workspace layout" dyn files in the file location where the others are stored. When I tried to manually download online from Autodesk official website, the page is "not found".
Is there a fix or another way to acquire the "Workspace layout" sample file to use for generative design?
julia_lubacheskiQ3DPX
Hi @lehaxathuc11 ,
The file you're looking for is attached.
I hope this helped you.
lauri_barnhart
Hello, @lehaxathuc11,
Just checking in—did the responses shared by @julia_lubacheskiQ3DPX help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
kal_houhouBIM01
Workspace layout.dyn doesn't work in Revit 2026 GD. I added it to the sample folder, I added it in a separate folder Revit 2026 GD doesn't see it. Is it the correct Dynamo version?
kal_houhouBIM01
I got this message trying to open the graph in Dynamo 3.x:
