No PCP file when export from Revit !! How to manage .pcp file creation ?
l.alaimoLSQ78
Observer Observer
l.alaimoLSQ78
Observer
Observer
Hello everybody,
I need a .pcp file from revit to print an dwg in autocad. But I can't find any .pcp file when I export a revit file to dwg.
How can I solve this issue ? Is there a way to manage the .pcp file creation in revit ?
Thx,
RSomppi
It should be in the same folder as the .dwg.
Use Index Color under Colors (in Export Settings).
ahmed.shaikhon
Observer
Observer
That worked, thank you!!
paul_brickler
So, if you select something besides Indexed color, you no longer get the PCP file?  I've been manually deleting those for years.
