Area Boundary problems
I am having problems with the area boundary.
I create a GIA plan and I draw the boundary line (Area boundary.jpg attached). However, revit is not recognise as 1 area only... It is dividing in 2 areas (Area Boundary problem.jpg attached).
Any thoughts on that?
Best,
Larissa
dzanta
there is something that is making revit think they are two separate areas.  look at the wall between the spaces...perhaps "uncheck room bounding" will fix it.
I tried making a basic model and getting the area command to do what you are saying and it defaults to making 1 area object for both spaces...
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Hi Dzanta,
I just find out some boundary lines were drawn in a closed workset.... So Revit was recognizing this line (wich I draw first) rather than the line that was showing...
Tks for your help!
Larissa
Malena_Mende
Observer
Observer
I had the same issue, and looking through the worksets also worked for me. The line that was splitting the room was in a closed workset.
