No grass in Enscape
No grass in Enscape
tonytwok
No grass in Enscape
tonytwok
I'm picking up the new topography of Revit 2024 but I already have a problem, with Enscape I can't visualize the grass. Strangely, if I apply other materials to the topography they appear, but the grass doesn,t. Has the same problem happened to anyone else?
syman2000
Which grass material are you using? Check the Enscape material editor and check and see if the material is set as grass
tonytwok
I simply started from the default topograghy material, I never applied other materials from Enscape. This what I did till 2023 version.
syman2000
Try using one of these grass material and see if the grass will appear.
tonytwok
I applied Enscape's grass and worked, thanks! Do you know why the other grass from Revit's library dodn't works?
syman2000
It will work but you have to switch them in Enscape material editor by define the existing material as grass.
