No Glass Curtain Wall
LanggamanXavierMassed
Message 1 of 11
I am trying to make wall studs which I use the system family: Curtain wall, but I if i put the "curtain panel" option to "none" it still uses the "system panel: glaze" so there is still glass. I dont know if using a curtain panel is the best way to model studs(they are exposed so i they need to be modeled) and it's helpful to know if there's a better way but I just want to figure out how to empty the curtain wall with only mullions on.
Replies (10)
Message 2 of 11
ennujozlagam
you can edit your system panel glass > remove the glass and saveas empty system panel and load into your projects and see if helps. thanks
Message 3 of 11
Message 4 of 11
Can't Find Empty System Panel
Message 5 of 11
Loaded it and it worked, I thought It really could not browse the empty,, i just needed to load the "empty panel" even if it appears to be in the Family in the project browser
Message 6 of 11
but the big problem here is that you can't apply the empty panel to slots with more than 4 sides
Message 7 of 11
The one you loaded only works for rectangular shapes.  You want to transfer the empty system panel from the architectural project template.
Message 8 of 11
dom.marrier
Observer
Observer
Hi, forgive the tag along. How do you edit the system panel to remove the glass?
Message 9 of 11
Download this file > Transfer Project Standards > Curtain Wall Types - to bring the Empty System Panel to your project.  Or, copyclip the curtain wall from this file and paste onto your project.
Message 10 of 11
dom.marrier
Observer
Observer
LEGEND! Worked a treat. Thank you so much.
Message 11 of 11
u0652677
Observer
Observer
Thank you!! I was having the same issue.  I downloaded your file and it worked perfect for me.  Thanks again!
