No Families to Load
No Families to Load
Swiffi
Message 1 of 26
No Families to Load
Swiffi
I'm not 100% sure what the problem is. I did a fresh install of Revit 2015 and I just noticed I have nothing to load.
For example:
Trying to load a door >  I go to door > load family > Doors > Only Single-Glass 3 shows up
Trying to load some furniture > go to component > load family > furniture > Only a storage file shows up and inside of it is Entertainment Center... that's all there is.
I have tried to update/install from the Revit Content Libraries from:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/I...
I even tried the bottom bit of this and everything was already good:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/R...
Replies (25)
Message 2 of 26
ennujozlagam
Hello, switch off your all your anti virus program and firewall, if you have McAfee anti virus try to uninstall first and reinstall later. Try again to repair or install again your Revit software and see if helps. Thanks
Message 3 of 26
Swiffi
It finished updating a lot faster, but theres still nothing in the folders...
Message 4 of 26
Swiffi
Can we bump these?
Message 5 of 26
ennujozlagam
@Swiffi hello, can post some screenshot of your RVT 2015 folder same as below. thanks
are you using correct template?
Message 6 of 26
Swiffi
I made sure to check the templates, as one of the urls i linked earlier told me to check. They all seem to be correct.
Message 7 of 26
ennujozlagam
@Swiffi hello, most of your them are missing? please refer to this LINK  and LINK on how to reinstall. thanks
Message 8 of 26
Swiffi
I did this multiple times, as mentioned in previous replies. I have doors and windows to use, as well as some components. But I do not have any families to load.
Message 9 of 26
ennujozlagam
@Swiffi hello, that was strange. did follow my suggestion below earlier? thanks
Before you install, try to delete files at  c: temp folder those cannot delete just skip. and refer to this LINK. thanks
Message 10 of 26
ennujozlagam
@Swiffi hello. download this file from screen shot and extract. you can get this file from this LINK. thanks
Message 11 of 26
Swiffi
I did turn off all antivirus and firewalls, it finished faster but that was all it did. I'll try deleting the temp files and if that doesn't work tomorrow I will reinstall.
I won't lose any projects or items in that project will I?
Message 12 of 26
ennujozlagam
@Swiffi hello, no it won't as long as you have the file (.rvt) .thanks
Message 13 of 26
Swiffi
Do you know where the folder for Revit Master XML should go?
Message 14 of 26
ennujozlagam
@Swiffi it goes to your c: download folder. id you can find go search?. thanks
Message 15 of 26
Swiffi
I meant, where do the master files go? Like it says I need to check to see if they're in <INSTALLATION_MEDIA>\Content\Revit folder. But I have no idea where that actually is.
Message 16 of 26
ennujozlagam
@Swiffi hello, it will automatically goes to your revit program, after extraction is done, reboot your machine and open your Revit program and see if you can load your library. thanks
Message 17 of 26
Swiffi
It downloads the zip to my downloads folder, then I can extract it, but I dont know where to extract it to. If i extract it to the downloads folder, it creates a folder called Revit_2015_MasterXML in the downloads folder. It does not extract to where it needs to go. So i dont know where I should move them to.
Message 18 of 26
ennujozlagam
@Swiffi please sse screen shot. find the folder where it belong. thanks
Message 19 of 26
Swiffi
What do you mean sse screen shot? And I have no idea where/ what folder I am supposed to be looking for, sorry.
Message 20 of 26
ennujozlagam
@Swiffi hello please see attached that is the folder you going to transfer your file that you just extracted. thanks
