No Elevations in the project browser?
I installed Revit 2014 on my Computer. But there is no Elevations in the project browser. This is a screen shot from my PC and I have attached installation log files. Please help me to get this working.
cbcarch
Try creating a new Elevation--there may not be any in the Project yet.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
cbcarch is right, if you start a project in Revit without a template, you only get Structural Plans, Floor Plans and Ceiling Plans. You will have to go into your Floor Plan view and create an elevation for it to appear in your browser.
WHEN I AM IN COLLEGE ALL THESE ELEVATION ARE THERE BY DEFAULT,I HAVE TRIED TO DO WHAT YOU ADVISED, BUT I AM NOT GETTING ANYWHERE.CAN YOU ADVISE FURTHER.DECLAN
chrisplyler
David_W_Koch
Then in college you must have started your project from a template that included the elevations.  Are you specifying a template file when you start a new project?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Sounds like you have started a template rather then a project. Or you used a project that used a template that didn't have elevations. You need to create your own elevations in this case.
