Hi
I am a new user to revit so i will try & explain my query the best i can;
I am using revit 2016, and i am working on a 3 storey block of flats, i created some levels that formed the floor plans grd to 2nd. I then formed the grd floor ext walls, inserted the flat layouts as a group, as the floor layouts stack up through the building this is where i go wrong, i right clicked on the grd floor plan made a duplicate without details renamed it 1st floor plan and repeated the same sequence to form the 2nd floor the problem now is that my 1st & 2nd floor ext walls relate back to my grd floor, i deleted the walls in the 1st floor and noticed i had deleted the grd, 1st and 2nd. In hienside i should have clicked into my 1st floor plan and had the grd floor underlay turned on then traced over & repeat the same excercise for the 2nd floor.
My question is how do i now make my externals walls on the 1st & 2nd floors independant of the grd?
Hopefully that makes sense to someone.
