Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Nivida Graphic drivers for Revit 2017
Message 1 of 9
1. I had disabled the Bios setting switchable  Intel Graphic HD 4600 but still the image to find the attachment
2. Why both Intel Graphic HD 4600 and Nivida Graphic k3100M graohic have kept in drivers on my LAPTOP ?
3. Should I select in Nivida Graphic driver than Intel Graphic HD 4600  ( OR )
     should I enable both  Intel Graphic HD and Nivida Graphic  the  in drivers?
Replies (8)
Message 2 of 9
DarrenP
i’m not seeing an error that just tells you that graphics card was not tested
are you having graphic card issues?
i am running an untested graphics card with Revit no issues with it
DarrenP
Message 3 of 9
Nvida Quadro K3100M has not been  tested with Revit 2017
it is problem or normal ? tell me please
Message 4 of 9
Normal.
Message 5 of 9
DarrenP
are you having issues with it?
DarrenP
Message 6 of 9
I had made BIOS SETTING " disabled for Intel Graphic HD 4600  but my laptop can keep with NIvida QUAROD Graphic driver   ?
IS THAT OKAY ?
OR
 I SHOULD BOTH ENABLED INTEL GRPAHIC AND NIVIDA GRAPHI QUARDO ?
Message 7 of 9
DarrenP
that depends on the laptop & the laptop manufacturer
disabling that in the bios can cause issues with certain laptops
that is a discussion you need to have with laptop manufacturer
DarrenP
Message 8 of 9
Viveka_CD
Hi @Anonymous
Please see the article on Autodesk Revit Hardware Certification FAQ
This should answer most of your questions!
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
Message 9 of 9
Viveka_CD
Hi @Anonymous
Also,use this tool for our Certified Graphics Hardware
Keeping the drivers updated from the manufacturer's website is good practice!
