Newbie question: does revit have Render ID / Material ID?
Message 1 of 11
Newbie question: does revit have render id/material id like in vray (VFB channels)?
Replies (10)
Message 2 of 11
SallyDong2005
Hi @Anonymous,
I  think your question is Revit related, not cloud rendering, so i move this topic to Revit forum for there may have more experts would be helpful.
Sally Dong
Message 3 of 11
Hi, Sally.
I'm not able to find where this question was moved to and since I have exackt the same question, could you please point out where can I find the answered topic? Your help would be much appreciated 🙂
Message 4 of 11
SallyDong2005
Hi @Anonymous,
This is the post you asked, but seems no reply and solution yet.
Sally Dong
Message 5 of 11
loboarch
I guess the answer is NO Revit does not have Render ID /Material ID.
To be honest I don't know what either of those terms are/mean.  So no Revit does not use whatever this is. Perhaps it has an equal but since I am not familiar with what Render ID and Material ID are I can really say.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 6 of 11
mauryarte
Render ID...    Is a render(elements)  that would go out with the render and IDs are specific addresses for each material, is a very useful tool for Post-production image in Photoshop, This is seen in Vray or other render engines and is used a lot in Autodesk software.
CM.
Message 7 of 11
aRcHiTeCt.JM
... no , there are none
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 8 of 11
Matt__W
@Anonymous every element in Revit has a unique ID number. Is this what you're looking for?
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 9 of 11
aRcHiTeCt.JM
... the question is if REVIT materials have ID, not if Dynamo or 3Ds max
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 10 of 11
Matt__W
But those element IDs are not FROM Dynamo. Dynamo is simply reporting the IDs of the materials within a particular Revit project. Again, every item in Revit has its own unique ID #. Unless I've misunderstood the OP's definition of "ID"??
Matt Wunch
Twitter | LinkedIn
Message 11 of 11
Viveka_CD
Hi @Anonymous
You can try Show ID* is a small but helpful tool for Autodesk® Revit® users to extract element IDs from Revit file and store in the element's project parameter, which is shown in the Properties Panel.
Material ID information is determined in software link 3dsMax
*I have provided a link to an application or add-in that MIGHT provide the extra functionality for which you are looking. Please note, however, this is not an Autodesk product or endorsement. You should take all precautions whenever you elect to download/install/utilize any application and do so at your own risk. Please review the developer’s documentation and disclaimers before proceeding to utilize their product(s).
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
