Network License Manager Upgrade for Revit Architecture 2017
After upgrading a client's LM Tools utility to 11.13, none of their existing Revit Architectures products would work.
I noticed while troubleshooting that the feature code for Revit Architecture 2017 does not exist (2017 Feature Codes) or is not published. This means that in the new license file, there will only be RVT_F feature codes and no REVIT_F feature codes.
So far the only solution I have was to ask Autodesk to generate a new .lic file with a Revit Architecture 2017 feature code added. This makes sure that there is a REVIT_F feature code for the Revit Architecture (2014 - 2016) files {note that this solution effectively doubles the 2014-2016 seats of revit in the .lic file. - unless i'm missing something}
Has anyone else seen this issue? I imagine this similar issue would happen if someone had Revit Structure/MEP and upgraded their LM Tools to 11.13.
Reference:
