I have a lighting device with a nested generic annotation family. to control visibility of the annotation i want to put it on a sub-category of "Lighting Devices". but there doesn't seem to be a way to put the nested family on that sab-category.
The only workaround seems to be to edit the annotation family, and create a sub-category to "Generic Annoations". One problem is, I would prefer to control visibility of lighting devices under lighting devices. But the other problem is that the annotation family also has a "label", which seems to not be possible to be assigned to a sub-category.
what other options do I have? What I ultimately want to accomplish is to show a switch symbol ("$"for example) only on lighting plans, but not on all other views. those other views only should show the actual switch (without symbol). So just making the entire Lighting Device category invisible wouldn't work. Fr example, I need to coordinate thermostat locations with light switch locations.
I attached the family in question in R2021 version (My current is 2022, but i figured more people can open 2021)
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
