Nested Family Won't Move with Host Family
m_blaine
m_blaine
I've created a door frame family with three types for standard frame depths (222, 172 and 146). I've then nested a door family into the frame family without issue and the door width and height movements, along with the type sets work as intended. My issue is that when i change the type from one frame depth to another, the nested door doesn't move with the frame, it stays where it was inserted. If I try and constrain the door to the "face of frame" reference plane, it says its over constrained but I can't figure out where.
I've attached both the frame family (FE-1) and door family (DE-1) for your reference. Any help is appreciated.
Secttor
hi @m_blaine
I only have Revit 2017, so cannot open you rfa's but from your description seems that you need to constrain the door to a plane that moves with the depth; don't try to constrain the nested geometry to the frame geometry.
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
The Error Message says it all. Basically you have 2 entirely different families -- one hosted the other not hosted (DE-3 vs DE-1).  To clarify: your Family Types parameter won't work with these two different doors.
Sahay_R
Solution to the 'over constrained' geometry that you are getting the warning about - Cut it and then Paste to the Same Place. That will remove the constraints and you can apply required constraints without further grief.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
